Does anyone know anywhere in the uk supplying swap kits?
or does anyone know if i can use wiring specialities.com R32 to 1jz loom on a spec 1 gtst?
Wiring Specialties harnesses are great and they would be happy to make you one that will work, but it will likely be a custom job that will take quite a long time, especially if you want the gauge cluster and the ABS to work. I don't think anyone does an off-the-shelf kit.
I am led to believe i can use the R32 loom but not sure?
ill be using an S14 subframe for an off the shelf mount kit from the states!
