1 - 20 of 57 Posts
Following EJH#25
Today I ordered some parts in an attempt to update my rear lights.
As some of you know, I made my own LED rear lights years ago and used the R34 Nismo version as inspiration. I had an idea recently whilst looking at the new R35 2014 rear lights and have decided to try and incorporate the CCFL rings into the design.
The end product should look like a cross between this:
and this:
Parts won't arrive for a couple of weeks sadly and I've got no idea how they'll look but I fancy a change after 8 years. :)
Following EJH#25
I've taken all the measurements and ordered the set that's nearest the right size.
126mm should fit just about the same as on the R35, proof is in the pudding I guess.
Worth a punt at $54.
Following EJH#25
Discussion Starter #8
Cheers Simon, thankfully I'm better with lights than I am with trying to make an image^ lol
I have LED lights on my 33 at the moment, I like the look of them as it gives it a more up to date look... Will be good to see what you come up with mate.
Owner of the MSNSPS
and this:
Matt - how are thinking to handle the low/high intensity for the light/brake light? Perhaps CCFL for normal lights and LEDs for the brake light.
Following EJH#25
Discussion Starter #13
CCFL ring will be sidelight, Ultra bright LEDs already in for the brake.
The CCFL is just an update to the existing lights as below, brakes off...
Brakes on...
Owner of the MSNSPS
Brakes on...
Ah I see. Makes sense. You might have a blank space on the CCFL (i.e. not a complete ring). Should look pretty cool either way. In the dark with just to CCFL illuminated it brings this to mind:
Following EJH#25
Discussion Starter #15
Yeah, that is my concern but I have ordered full rings so will see when they arrive. If they're not full rings, I have a fallback plan ;)
1 - 20 of 57 Posts
