1998 GTR V-Spec Marine Blue .. in waiting
With the assumption this located below the IP, above the ECU/ECM, this looks like it may be a "joint connector". If this is a joint connector there should be mating connector that joins certain pins. The engine harness joint connector is joining various ground and shield circuits. Note: They are not all tied together.
Line Font Rectangle Parallel Electric blue
