I'll be fitting a set of these to my front bumper very shortly. Can someone please measure the centres of their vents so i can get them in the exact position? Also what would be best to cut the front bumper? Standard bumper by the way.
Will try to remember to do it tomorrow mate.
Use a dremel or something like that i would have thought then get some 80/180 grit sandpaper to smooth off the cuts you make.
thanks mate, it would be much appreciated if you could get the measurements. Think ive got a dremel type tool in the garage somewhere
You will also have to have some sort of a die grinder to cut the slots into the bumper beam.
