1 - 7 of 7 Posts
I recently sold my Fairlady Z33 real calipers and brackets for them to fit a GTR (and other Nissans) using 370z rear discs, geezer on eBay doesn't appear to have any of the brackets listed anymore either. Upside 370 rear discs are cheaper, downside is you end up with bigger discs at the rear than front!
Must they be R32 / R33 Brembos calipers For the front?
I ask because I fitted Z33 Fairlady / 350z calipers, new piston seals and dust boots, c hook discs and brembo pads for cheaper than it would be to have bought 33 GTR calipers alone, and I didn't drill the hubs either, used 4 wurth timeserts (2 for each caliper) which reduced the m14 bolt hole to m12
Set of 350z Brembos can be had for between 3-400 quid, and not 800+ for one's from a 32 or 33 probably just a front set.
Yep a reason why I am looking for the rears but people who have then have been reluctant to part w only the rears.
I do recall earlier R34 GTR Brembo calipers being easy to do on the 32, later rear R34 calipers need a bracket
these are on eBay
Discussion Starter #6
No they don't have to be. I got myself a set of G35/Z33 front Brembos and will going down the route of using time serts.
Still trying to find a rear set that is decently priced. I might go with 04-06 STI rear brembos but need to figure out which rear rotor to use.
Needless to say... bump for rear R33 Brembos (hopefully minus the skyline tax)
Discussion Starter #7
Since the 260RS (Stagea) uses the same rear Brembos as the R33, I bought those instead from Yahoo Japan. I also found out that the STIs are not a good upgrade since the piston diameter is 36 compared to 38 on even stock R32 calipers.
Please close thread.
1 - 7 of 7 Posts
