Depends how much you;re paying for them.
I personally went the DIY route as you can get some VERY high quality (better than OEM) projectors + bulbs in any K you want + custom cutoffs and shrouds, bi-xenon too! from The Retrofit Source over in the US.
Went thi9s route as i have a spec 2 gtst front end, but even then it cost me around the 200 mark with a discount code including shipping.
This gives you the opportunity to find a good set of headlight lenses too that arn't marked up / yellow as a lot of headlights for sale now have some major wear on them and it's becoming increasingly hard to find a set with the mounts still intact , let alone with them getting broken in the post.
Will post pictures once it's all done, going for vented high beams too
