Hi all
Here we have for sale a very nice set of R33GTR front 1000BHP driveshafts like brand new, we also have a Driveshaft Shop R33GTR Alloy propshaft for sale again like brand new.
The Level 5 complete front axles for the R32 / R33 / R34 GT-R. The axle center bar (the weakest link on the factory front axles) has been upgraded from the small stock 27 spline to our larger 36 spline bars made from high quality aerospace grade material. These axles feature a billet inner CV and spline plug into the differential on the male side and a billet bolt-on inner to mount to the drive flange on the opposite side. The outer CV is made from a proprietary material and has the ABS rings installed. Capable of 1000HP and can be used for street or drag with no modifications required. £800 These cost £1380 new.
This is the complete Aluminum Driveshaft for the Skyline platform,This is a 3.5" 6061-T6 aluminum shaft that uses a CV in the rear but has had the internals changed to a higher grade chromoly and is a direct bolt on. This single shaft eliminate the factory 2 piece shaft. By removing the factory 2 piece shaft the car will lose the excessive motion caused by the hanger bearing moving up and down when you step on the gas. This will make the car react faster to throttle input and make the car feel more responsive. Rated to 1200HP. £550 this will cost you £860 new
Please call us if you have any interest:thumbsup:
Regards Mark
