was trying to look for specs but couldn't find it... what is the maximum possible boost that the R33N1 turbo's can put out? just a curiousity thing...
Thanks for anyone who knows.
How longs a bit of string?
Do you mean reliably? most turbos will run 3 even 4 bar just not for very long.
I think the normal levels of boost are anywhere between 1.4 and 1.8bar, but this is probably down to the level of tune on peoples engines, as in you wouldn't have a fully 'built' engine with 700/800brake potential and run it on turbos that are over their limits on boost
i was just curious with if there was no actuator to limit boost physically what boost pressure could the R33N1 turbo's produce, i know its not limitless :p has to be some finite number i would think but what that number is??? was looking for that statistic but couldn't find it... just for curiousity sake, no other reason...
as you mentioned it could run up to 3 or maybe even 4... i was just looking for an actual definite number... thanks to anyone who might know :)...
