1 - 8 of 8 Posts
Hi all,
Just putting some feelers out really. If I confirm my car has tits turbo(s) then I will be replacing them and may as well do these at the same time! :chuckle:
W.H.Y?
Cheers.
Does anyone know if it is an advantage to have the separate waste gat tube or not? Seems like mines, hks, and the like have a separate tube.
Not much unless you are using divided turbos such as the HKS2530's which will then match up to the Mines outlets perfectly. Benefit is gas separation and almost eliminate turbulence.
1 - 8 of 8 Posts
