1 - 11 of 11 Posts
I have read that the diff ratios are different between the two gtr models.32 - 34
Whats the deciding factor over the diffs? Do the front and rear diffs need to be matched? or is the ratio matched to the gear box? I have no clue and would really appreciate some help.
so is it just a case of matching the front and rear diff...
So i have the 34 diff in the front now and if i got a 34 rear diff it would be correct ratios then and no probelms?
how will the difference in ratio effect the acceleration of the car? will it be quicker off the mark with the 34 diffs in? or slower with more top end....sorry if it sounds dumb i am clueless at this stuff
4.11 gear ratios are way quicker acceleration... Another reason why R32s are the best! :)
if you doing the r34 engine into the r32 there are other considerations.
if i'm not mistaken the speedo drive is manual on r32 whereas on r34 it is electronic. Gearbox on r32 was push on some models and pull on other models. Not so sure that r32 box will work straight on r34 engine.
1 - 11 of 11 Posts
