Hi. My friends mfd is not wprking properly. Since purchase from Japan his injector duty cycle qnd boost pressure monitors do not work both just sit on zero. Checked boost sensor is working but the sense wire has a solid negative coming from loom . It normally should have a slight bqck feed if i qn correct. Any help would be appreciated.
