Hello GTR tech-gurus,
As I am planning a engine swap in my R32-GTR I need some useful information on the front transmission gear ratios.
Q#1: Does the front final drive (integrated with oil-pan) for the R34 have the identical gear ratio as the standard R32, or do I have to replace the parts to get a proper function of the traction control system? Ideas anyone?
Q#2: Are the turbochargers interchangeable (will R34:s fit on R32 without mod:s of exhaust manifold, etc.) ?
Lars Borbos
Sweden
Hej Bobban,
The only reference I can find on this site to the front dif is a quote about using a beefier one on the R34, so if space is an issue then it is probably not going to fit.
I have never even looked at this point on either of the cars mentioned.
The other worry is the final drive ratios are different so there could be a difference there.
I suppose the most unscientific method would be to try the front dif for fit.
As for the turbos, Dunno, I know some people have 34 turbos on 33's without too much grief, does anyone know if the 33 turbos ft a 32 ? if so I'd say you were on a winner.
Hope this helps.
Steve
Have a Look at Tuning Gerneral
Under Filter Survey Nigel says he has got new R34 turbo's on his R32 GTR. He might Know..
Many thanks guys, for your help and tips.
PS.
I found that the R32 final drive ratio is 4.111 (looking in a GTR Workshop manual) and that the R34 ratio is 3.545 (as from Middlehurst Motors web site).. So I will probably have to fit the original oil-pan/diff not to "upset" the torque transfer system.
//Cheers
Lars B.
