I wonder if anyone succeeded in reading the stock ECU with Nissan Datascan.
The program´s feature does admittedly not work on all ECUs, but it seems to me like the reason is just that the program is initializing the dumping process wrong or it tries to start at the wrong memor address?!
Furthermore, does anyone know the memory address of the knock counter or
did anyone care about disassembling the stock ECU (at least people who do remaps must obviously know details but will most likely not share them...?!)?
Reason is I think it may be a useful parameter to know even if you can´t flash the stock ECU and because you can log a known memory address with Nissan Datascan.
thanks
peter
