Thought I would put these up for sale to clear my garage. All off a July 2000 R34 GTR v-spec. Most parts were removed at about the 25000km mark or before. All in working order when taken off and no problems.
PM me if you are intersted in any of the items
OEM 6 Standard coil packs
OEM Oil pump
OEM Water pump
OEM cams plus pullies
OEM AFM's (2)
OEM 444cc injectors (6)
OEM fuel rail with standard FPR
OEM engine mounts (2)
OEM gearbox mount (1) for crossmember
Full set of standard brake pads, hardly used
OEM clutch slave unit
OEN clutch, cover plate and flywheel
Nik W
Discussion Starter #4
OEM Oil pump
OEM Water pump
OEM AFM's (2)
OEM 444cc injectors (6) SOLD
