Hey Everyone.
I Have the chance to get my hands on a R34 Gtr with some frontal damage, 2 of the most important parts are no longer available from Nissan so I'm wondering if there is maybe a few of you that know a bit more about which chassis parts are interchangeable between a few of these models which have similar chassis.
- Stagea has the same part number.
- Im assuming R34 GTT chassis rails up front will be different as they didn't have 4x4, by memory the GTR has the Notches in the chassis rails for the Half shafts to go threw. (Worst Case if only the Notches are missing I could modify the R34 GTT rails and just notch them)
- I could track down a R34 GTR front cut and drill and cut everything out but I would prefer having all new parts as it would be easier and cost the same, by the time I've drilled and cut all the sections apart.
Parts Which are no Longer Available.
1x Nissan 75100-24U30 - REINFORCEMENT NO LONGER PRODUCED
1x Nissan 75101-24U30 ***8211; REINFORCEMENT NO LONGER PRODUCED
Kind Regards
Stefan Etter
Hey David.
No. I don't own the car but have the chance to buy it. just want some more advice on the chassis parts.
Hey Everyone.
1x Nissan 75101-24U30 – REINFORCEMENT NO LONGER PRODUCED
Take a look at the attached Google Drive Folder for photos of the Damage.
https://drive.google.com/drive/folders/12hdjEVGoVMLlDFL6l_RR37VzKGx9gZQj?usp=sharing
Kind Regards
Stefan Etter
Nissan have added the R33/34 to the heritage parts run by nismo so there is a chance it might be available. Otherwise why not get your own ones fabricated?
Hey FRRACER
-ill check the availability there as well thanks
-having one fabricated is a good idea to, I have a friend who isn't to shabby on CAD we could even draw it 2D then Laser it and fold it all together. (Probably a bit overkill but im a bit of a perfectionist)
-Do you know of a company that Fabricates structural panels or rails? they would need a example piece then wouldn't they? so in order to have one re produced I would have to get a front cut anyway and remove a good condition section which they can copy of correct?
-Or are there companies that have data 3d-2d files of these parts and they can just remake them?
Thanks for the suggestions.
