1 - 10 of 10 Posts
Hi All,
Thanks for all your feedback on a previous post about rebuilding the R33 gearbox vs a 6-speed R34 gearbox. I'm leaning towards converting my transmission so that I can use an R34 box on my car, could someone please outline the parts I will need for the best setup.
I know I'll need the gearbox (obviously :p ) and a new clutch as the R34 clutch is a pull type clutch, instead of R33 push type (according to exedy).
What else will I need to replace? Thanks
Shah
Real men use a H-Pattern.
No you don't.
32/33 diffs are much better with the Getrag.
Gearbox, transfer box, front prop, front half of rear prop, clutch/flywheel and a cross member or modify the 33 one.
...and yes, this has been done to death.
Argh sorry!someone told me wrong when I posted asking the same question then!damn you!that was the main reason I didn't do it as diffs etc aren't cheap!
Discussion Starter #9
Thanks everyone for your comments - apologies for going over old ground.. Perhaps worth making a sticky if its a common questions? When I get it done, I'll put pictures up - Hom @ MIJ Performance are going to carry out the conversion.
1 - 10 of 10 Posts
