Brand new and never fitted. Still in original box from Japan. Contains 2 lamp units and the fitting brackets for the standard front R34 GTR bumper.
You will need to obtain the modified black plastic grilles that sit behind them as the lamps seat deep into the brake vents. I have one of these modified grilles (passengers side) in used good condition which the buyer can have. It would be easy to modify a standard one for the drivers side.
You will also need two 1" by 1" double sideded stickypads for the brackest (one each side).
Also, you need a fog light switch for the cabin to go into the blanking plate in the dash to the right side of the steering wheel. I guess this is a standard Nissan item that could be obtained reasonably easily.
I think these are a really rare item as the only R34 I have seen them fitted to was my own! This set I am selling are new and NOT used.
£150.00 plus postage
Nik
