1 - 19 of 19 Posts
Guys,
Remembered that ive got this kicking about.
Its the orignal R34 GTR rear carbon fibre diffuser which came off my 2001 34 GTR.
Its in good condition and ready to be bolted on.
EDITED TO SAY: the brackets are not all rusty like others i have seen!
Reduced to £600.
Harry
Discussion Starter · #8 ·
Pictures sent but just to clarify this is the REAR carbon diffuser that comes standard on all R34 GTR V-Spec models.
Discussion Starter · #10 ·
Sorry guys, getting loads of PM's about this!!
PM box now empty.....and replied to PM's also.
Harry
still for sale ?
can you tell me if that would fit on a standard GTR (ie non v-spec) ?
just going through that:
there are some welded on studs on the outside of the spare wheel well on the v-spec, there´s a bracket available as a spare part you will have to somehow attach to the body of your car.
then the standard model lacks some brackets/mounting points that hold the front part of the diffuser, i am currently researching that together with Newera, supposedly 2 stays (rh and lh, respectively) are different between standard and v-spec models which have to be changed.
again, working that out right now. i´ll keep you informed if you want.
peter
1 - 19 of 19 Posts
