1 - 12 of 12 Posts
Hi all looking for a r34 gtr speedo 300km black faced, can be nismo or non badged.
Harry
Would the dial just fit into the existing speeding? Easily done? Thanks
If not I’m sure it can be calibrated as I’ve bought one of the last UK spec’d 200mph ones and Rod at Rbmotorsport said he can recalibrate it if it doesn’t just work.
Temperature Gauge Measuring instrument Gas Auto part
Discussion Starter · #8 ·
Ive seen it done somewhere. Nissan sell the 300km dial, surely it must be able to be calibrated?
Is it plug&play or its necessary to adjust it
It's only plug & play if you have the Nur cluster assembly. If you have a Standard/Vspec cluster assembly designed for 180kmh, then Nur 300kmh speedometer will need to be recalibrated by flashing the chip on the mainboard or using a speedo corrector interface module. I think the easiest DIY method is using Dakota Digital SGI-100BT which can be calibrated using mobile app.
References:
Jaycar Speedo Corrector
Dakota Digital SGI-100BT Speedometer Calibration & Interfaces
1 - 12 of 12 Posts
