hi there drove down to greece , non stop 1400miles , with out any problem
2 days after i arrived ,the car was feeling stange when im off trottel ,it can not keep revs with out trottel , theye told me here that it might be the crappy fuel i putted in as i arrived in greece , so whe changed the fuell filter , and putted 100+ vpower in plus a bottel off octane booster , seemed to solved the problem but 2 weeks later after 3or 4 refills with octanebooster as a suplement ,yesterday it started again , when we changed the fuell filter there was alot off shit in , could it be that as i was runing low on fuell the fuell pump sucked in stuff ? has any body had something similar , the gasket on the inletmaniafold on the engine is ok , it must be somthing with the fuelling , help me out on this cause i need to drive back in 10 days ,
