101 - 110 of 110 Posts
Discussion Starter #103
Some work today. I put in place the front propeller shaft and the slave cylinder clutch, and bad news it is not the good one ( it works but it is not clean)
266370
266371
266372
266373
I put the fuel cap too
266374
266375
266376
And to finish i put the front brakes.
266377
266378
266379
Discussion Starter #104
266380
266381
266382
It was just a test for the brakes, now i have to buy the dust plates and the brake lines and fix the passenger shaft before to install it definitely.
266383
Great progress mate. Getting closer to the first drive! Have you managed to source all the bits you need to get the engine running?
Discussion Starter #108
what parts do you need, have you a list?
Hello Yvon,
I put a list here but it is not exhaustive:
I have a bare engine and gearbox so i need all the component, water Line, air Line, oil Line. I have just the pcm valve, the canister, the intake manifold with the throttle body
266423
And i am looking for the steering tank and the washer tank too.
