1 - 13 of 13 Posts
which order are they in terms of which is better
z tune is at top
then is it a v spec 2 nur?
is r1 and r tune the same thing?
and were do the m spec and s tune fit in , in terms of desireablity and rareness.??
Its all.based on condition
Non v specs can fetch more than vs depending on condition
Can be fitted with s or r tune engines
If what your asking is
What version you should import to sell then its depends on who the final customer is
Skyline Section Manager
Said better than I could. lol
Or to be honest and my replies not meant to be sarcastic but i guess you looking to import a 34
Find the full details on wiki -spec ?production numbers etc
Some34s will fetch upward of 50k easily in japan
Depends on shaken etc
Aftermarket parts not so much
People /dealers buying these types of cars are at the top end
Look at global auto for ideas on price
Also you cant see under the bonnet unless you at USS
Which is important as cars can be mis labelled-critical when small differences in 34s make big differences in if its a genuine example
Ie interior swaps or bonnet /brake changes
Discussion Starter #7
no I wasn't asking that at all to sell.
I know the z tune is the top, just really wanted to know if R tune and R1 was the same thing, same as S1 and s tune? were they factory build nismo cars or just nismo packages fitted afterwards to normal cars.
just a little confusing.
s tune can mean a number of things- from components which are called that, to the series of tune
R and S are different
yes they are factory built, but not from the production line.
ie from nismo not nissan & built afterwards.
will come with full documentation on its specification.
think i took this picture in 2004 or 5, cant remember but at the old omori factory with Dino, Bean etc
this is an S1 engine
still looking for somthing special ?
1.hour flying from you amar!!!:thumbsup:
1 - 13 of 13 Posts
