1 - 10 of 10 Posts
R34 GTT 400hp Power upgrade
All parts are NEW unless otherwise stated. All new parts are UNFITTED and only removed from the packaging for photos. Packaging may be dusty and/or have minor over spray but the items are unaffected
** I can hold item(s) with a 10% deposit (non refundable) Items will be held for 14 days unless otherwise arranged with the buyer **
Collection from Norwich, Norfolk is welcome
Postage is within the UK (Northern Ireland postcodes may be slightly more)
New Hybrid Turbo (rated to 420hp) stock OE unit rebuilt by Universal Turbos £840 posted
New Tomei Turbo Elbow £270 posted
New Genuine Turbo Gaskets £75 posted
Used Walbro 255 Fuel Pump £45 posted SOLD
Used Apexi Power FC w/ commander £620 posted
Used Z32 MAF with Apexi Filter £100 posted
New Competition Clutch Stage 2 Clutch Kit & Lightened Flywheel £700 posted
New Braided Clutch Line £25 posted
New Splitfire Coilpacks £400 posted SOLD
Turbo Specs are
Re-Profiled Compressor Cover
T38 Compressor Wheel
360 Degree Thrust Bearing
T3 Billet Backplate Modified
T3 Bearing Housing Modified
Hi-Temp Turbine End Piston Ring Seal
T38 Turbine Wheel
Re-Profiled Turbine Housing
Ported Wastegate and Larger Poppet Valve
1 Bar Actuator
Up-Rated Actuator Bracket
Hey bud, hope all is well.
Not going ahead with your performance upgrades no more, going another route or circumstances changed hope its nothing to serious if so.
Discussion Starter #7
Copied from the original advert (R33 GTR uses the same pull clutch as the R34 GTT)
Complete Clutch Kit- Conceptua Tuning
Uprated Stage 2 Organic Kit-
With Lightened Flywheel !
Competition Clutch
Conceptua Tuning offer this uprated Stage 2 Competition Clutch Clutch Kit complete with Lightened Flywheel for R33 GT-R Skylines with the RB26DETT engine. These Clutches are Pull Clutchs. This kit has been produced to offer strong engagement thanks to its improved steel backed friction disc, complimented by stronger clamp load from the uprated clutch cover.
  • R33 GT-R Skyline- RB26DETT
  • PULL Clutch
  • Stage Two Uprated Organic Clutch Kit from Competition Clutch
  • Comes Complete WITH Lightened Flywheel!!
  • Smooth Engagement
  • 425 Ft Lbs Torque Handling at the Wheels
  • Resistant Steelback Friction Disc
  • Uprated Clutch Cover Clamp Load
  • Kit Contents-
  • 1 x Steelback Friction Disc
  • 1 x Uprated Pull Cover Plate
  • 1 x Lightened Billet Flywheel
  • 1 x Pull Style Release Bearing
  • 1 x Spigot Bearing
  • 1 x Alignment Tool
1 - 10 of 10 Posts
