HI all, is the reading on the MFD is the same reading that the ecu receive?? Well, the problem is that my boost sensor died. So will that mean that the ECU is not able to read boost (Thus put in more fuel or something?)
Hi.If your car isn't changed full computer like MOTEC.It is no problem that boost sensor died.Because ECU doesn't read on that sensor.
Boost is controlled by pcm valve.ECU read out Air Flow sensor then decide to inject how much fuel into engine.
