To spark up a thread from the old BBS... where it was said that the R34's MFD may be inaccurate...
When at Tuning Japanese their printout shows my R34 at a pretty aveage 1.15bar from 2,800 to 8,200 rpm. There were a lot of fluctuations +/- 0.1 bar from visual inspection.
The MFD pretty much agrees with this; though T6yko, oddly, got an under-reading judging from his post. My MFD's readings at the dyno day were very close to what the dyno readings gave ... I ven downloaded the session to a PC and corrolated the dyno's boost trace with the MFD's readings.
I got an average of 1.16 over the "peak boost bit" from 3,030 to 7,860 rpm. Peak was 1.25, min was 1.07 and it fluctuated quite a bit as both readings showed.
So maybe mine's better calibrated, or maybe my replacement Nismo MFD II's turbo boost probe is more accurate?
