R34 carbon fibre interior trims
Thought Id offer you guys these for my 50th post, a few little bits for the R34 GTT and possibly other models;
R34 Carbon fibre interior dress up/ trim;
Carbon fibre weave with clear flexible enamel outer coat (2mm thick not a sticker), moulded for a direct fit, can be heated and manipulated to fit tighter. 3m self adhesive back that sticks strongly to a well prepared surface, additional contact adhesive can be used aswell in place like corners etc.
Gear surround piece, fits the whole panel (please check the shape in picture for application)
Slight rippling on the surface that is barely noticable, only if you look hard in line with the surface can you then see it, I just polished a test patch quickly and it has brought this off abit, so will buff it up to a good standard then package it.
Ripples;
Same area as above after a polish;
Triple gauge pod enclosure surround, fits around the pod face for R34 GTT
Again, Slight rippling on the surface that is barely noticable, only if you look hard in line with the surface can you then see it, I just polished a test patch quickly and it has brought this off abit, so will buff it up to a good standard then package it.
Gear surround £10 Gbp deliverd UK mainland
Triple Gauge surround £5 deliverd UK mainland
More bits to follow shortly.
Ripples;
