Hi Everyone,
Time has come for my to sell my R34. I bought this in 2007 as a stock NA RB20 and at 1st converted it to run RB26DETT and then a single turbo RB30DET.
The RB30 engine was built, run in and mapped by Martin Battye at MB Automotive and has done less than 6k miles.
Oil pressure is 6 bar cold and 4 bar at idle warm
Oil changed religiously every 3k miles
Only ever run on Shell V power
Taxed til jan 2014
Mot til jan 2014
RB30
Greddy intake + Custom breather tank
Billet comp T4 turbo and Zircotec coated RIPS Manifold
Turbo Smart 60mm wastegate braided boost lines
Nismo LEDs
Power run
Spec list:
Engine
RB30 bottom end
RB30 block - 0.5 overbore
Custom domed forged pistons 86.5mm
ARP big and main race bearings
Forged conrods
Full bottom end balanced
R33GTR head
Ported and polished + squish area from head removed
Tomei 260 poncams
Bronze valve guides
HKS cam pullies
Clear cam pully cover
RSP head drain kit
Mines cam baffles
Apexi head gasket
N1 Oil pump
N1 water pump
Nismo thermostat
Nismo engine mounts
HKS oil cap
700cc injectors
DoLuck Coilpacks
4 bar map sensor
HKS fuel rail
Fuel Lab pressure reg
Greddy intake manifold
Custom pipe work for intake manifold
Trust 3in Intercooler
Walboro lift pump
Bosch 044 main pump
custom swirl pot
19 row heavy duty mocal oil cooler with filter relocation
Mocal Power Steering cooler
50mm big rad
Link G4 ECU : 600hp at 1.5 bar
Turbo set up
Comp GT35 - T4 billet turbo
Rips twin scroll manifold
Turbo jacket
Turbosmart 60mm wastegate
Custom down pipe
Zircotec ceramic coating – Manifold, downpipe and Turbo back housing
Japspeed stainless steel exhaust
KN Filter - 4 in
All boost lines braided hose
Braided water hoses – AN fittings
Drivetrain
RB25 gearbox
Exedy twin plate clutch
Nismo GT pro lsd
GTR drive shafts
Nismo big clutch cylinder
Braided clutch line
Nismo gearbox mount
Suspension
Brand new CS2s coilovers
Cusco upper camber arms
Tein steering rods and ends
SuperPro steering rack bushes
Japspeed tension rods
Subframe locking collars
Solid diff bushes
Garage D custom Hicas delete kit
Nismo braces
Nismo Anti roll bars
Nismo spec suspension arms - Powder coated with superpro bushes
Interior
Nardi wheel
Defi digital display
Blitz turbo timer
Profec B boost gauge – link ECU controls the boost
AEM Digital Wideband Air/Fuel Gauge
Wheels
17x9 et 12 final speed
Exterior
Seibon carbon bonnet
Knight racer carbon boot
Knight racer carbon mirrors
Nismo rear LED lights
Clear front indicators
Clear side repeaters
Arches professionally rolled for wide wheels
Price is £15,500
Contact on : 07021539058
Located in Welwyn, Herts AL6
Taxed til jan 2014
Mot til jan 2014
RB30
Nismo LEDs
Power run
Spec list:
Engine
RB30 bottom end
Forged conrods
R33GTR head
Tomei 260 poncams
Bronze valve guides
HKS cam pullies
RSP head drain kit
Mines cam baffles
Apexi head gasket
N1 Oil pump
N1 water pump
Nismo thermostat
Nismo engine mounts
HKS oil cap
700cc injectors
DoLuck Coilpacks
4 bar map sensor
HKS fuel rail
Walboro lift pump
Bosch 044 main pump
custom swirl pot
50mm big rad
Turbo set up
Turbo jacket
Custom down pipe
KN Filter - 4 in
Drivetrain
RB25 gearbox
Nismo GT pro lsd
GTR drive shafts
Braided clutch line
Nismo gearbox mount
Suspension
Solid diff bushes
Nismo braces
Interior
Nardi wheel
Blitz turbo timer
Wheels
Exterior
Price is £15,500
