Hi from Australia!
I've offered these to the guys locally and thought maybe some people over here would be keen as it can solve a few problems caused by forgetting to turn the TCS off in R34's so here goes:
Do you find it annoying to constantly turn your TCS off?
Do you wish it defaulted to 'TCS Off' the second you started your car?
Do you have a modified valve body/manual that chirps gears and hate TCS kicking in when you leave it on?
If you answered yes to either of those questions, this is for you!!!!!
The device when fitted to your car will instantly turn off the traction control, you now have to press the button to turn it on! (reverses the factory setup) The circuit can also be wired so that it's selectively on (great if your girlfriend is going to drive the car and you want TCS to come on the second she turns the key!!!!!!)
Easy to wire with only 3 wires to the ECU in the boot:
Only $AU30 + Postage
Actual unit may vary slightly from picture, new improved wiring version only has 3 wires!!!
