Purely for reference,
the following extracts were taken from tyres-online.co.uk...
AVS Sport
Sport Auto's reviewers (6/00) rated this tyre as generally average, although it did offer good dry traction on the rear axle and the lowest noise levels. The test recorded a slight delay in steering.
Rallye Racing (7/2000) praised the tyre for good dry performance but criticised the tyre's aquaplaning capabilities.
Eagle F1
After a very good aquaplaning and wet braking performance, Sport Auto's reviewers (3/00) recommended this tyre to consumers. On the downside, when pushed to the limit it tended to understeer, dry braking was unsatisfactory and handling was only rated average.
Bridgestone Potenza S-02
This tyre came joint first with two others in Sport Auto's test (6/00). The reviewers found its agile handling and precise steering with high aquaplaning resistance made it easily controllable in the wet. The S-02 also performed well in the braking test but offered low traction on the rear axle on a wet surface.
T1-S Proxes
The T1-S was rated above average in most sections of Auto Motor Und Sport magazine's test (6/00). It did very well in the handling and driveability tests but was considered poor for resistance to aquaplaning on a straight line and for rolling resistance.
This tyre gave a good performance under wet conditions in Sport Auto's test (6/00) where it offered excellent traction, steering precision and braking. In the dry, however, it provided imprecise steering and low traction.b Aquaplaning was also described as a weakness.
Not that I'm biased of course....
