1 - 6 of 6 Posts
i've done some search about it and know this subframe is better than the originial if you build a track car but i want to know if its bolt on or if it require some mod to fit it? does the r32 arm fit or you need all the rear r34 suspension arm and everything??
thanks!
AFAIK you would need to have some subframe bushes made with offset holes as the R33 and R34 frames are wider.
I know R33 can be made to fit using offset bushes but no idea about 34.
does it worth to do this or just reinforced the r32gtr subframe will do the same? what make the r33 r34 subframe more for the track use?
not sure about the specifics, but this swap is easily done. The S14 rear subframe is also basically the same thing with the same results.
I've considered, then rejected this swap on my R32. It does improve handling and the R32's tendency to sometimes kick the tail out, but I believe it would neuter the "raw" feel of the original RB26 GT-R. And I have little complaint about how tenaciously my R32 handles so...not worth the time or expense to me.
1 - 6 of 6 Posts
