1 - 20 of 61 Posts
R34 GTR V-SEC
Don’t believe I have to do this so be kind and no stupid offers.
A little about my history with skylines
After building and owning
R32 GTR 650bhp
R324 GTR 650bhp
R32GTR 700bhp
R35GTR 650bhp
I have finally got myself an R34 GTR Victory spec
The car I brought here from GTROC member.
It was a Japan import, Magazine featured show car for CRD
http://www.gtr.co.uk/forum/152182-r34-gtr-v-spec-mag-featured-show-car.html
This was the base of my ultimate build.
The build was finished September 2013 and has completed about 1000 miles on a low boost setting 1.3bar to run the car in. Now tuned with 1.5bar
I can honestly say that the only upgrade left on this car is a fuel swirl pot. And I have already brought a very trick twin bosch setup that will be sold with the car.
Reason for selling is that I no longer live in the UK.
Engine specification built by RB Motorsport.
With all new parts, only the actual head was reused and that was completely reworked.
RB 2.8 single turbo.
New N1 block and crank cradle. Improved over the standard 24u
Fardons stroker crank.
Tomei rods
Greddy cooling line pistons.
Nismo bearings.
N1 water pump, low temp stat.
ARP bolts
ATI crank damper
Nissan Gasket set.
Converted Dry Sump
Triple scavenge pump
ATI crank drive.
1” braided lines to rear boot tank
Aluminum split tank for cleaning.
1” braided lines to oil cooler
Remote oil filter High flow
Cylinder Head
Mild port and polish
RB Oil gallery bypass
Sinter valve guides.
Stem seals
Buckets and re-shim.
HKS cams 264º inlet/ex
Tomei adjustable cam pulleys.
Tomei Belt
Full Tomei metal gasket set, Head gasket 1.2mm
Turbo set.
Garret GTX 3582 twin scroll
6 Boost twin scroll manifold
Twin turbo smart blow off valves, Plumbed to down pipe.
RB 4” down pipe.
Titanium exhaust with 2x high flow resonators, to keep the noise down for track days.
Induction
Nismo Plenum this is a work of art and due to the cost of them they are very rare in the UK..
Hard pipe set
Apexi GT Intercooler
HKS SSQV
K&N massive filter with 4” hard pipe.
Fuel
Twin nismo in tank pumps
Braided lines
Twin Nissan filters
HKS fuel rail
1000cc injectors.
Cooling
Large aluminum radiator
13” Twin HD Kenlowe with duel temp control.
Clutch Carbonnetics twin carbon clutch 1350 pressure plate, type “R” drive. Rated 800bhp
Suspension Ohlims road and track.
Wheels volks Rays, powder coated satin black.
Brakes GT spec Alcon
355 disc’s all round and Alcon GT 4 pots rear 6 pots front.
Performance friction 010 pads
These brakes are awesome and well balanced.
Gauges
MFD upgraded to Nismo
280khm clocks
AME air/fuel
HKS Boost controller
ECU Link G4
Red Top Battery
Body modifications
Nismo skirt set.
Carbon vented bonnet, painted
Garage Defend carbon cooling panel
TS front splitter with under tray.
New GTR badges
I feel that this car is a 50.000GBP car easily. But understanding the market Im asking 37.000GBP
PM me your interest.
Thanks jambo
A note to anyone interested in viewing my car, I will be back in the UK on the 16th and the car will be viewable for 3 weeks. after that time Ill be looking into a 3rd party for selling.
Oh My what a car.. cant believe you are selling mate.
will you still be joining for a ring trip or two in the future?
GLWTS
Love this car. Any more pics and power figures?
Awesome. Excellent value for money. Quality speaks for itself ;)
Discussion Starter · #9 ·
More pictures on the 16th
No dyno as RB Live map, road tune.
Discussion Starter · #11 ·
What does RB estimate the power to be at the boost its running?
turbo is good for 750bhp engine alot more, on its present map Id guess 650-680
Very nice. So I guess on the new fuel system you will get close to the 750hp.
What was the engine built to handle?
Discussion Starter · #13 ·
Engine was built for strength and reliability one of the main reasons for the dry sump option, to eliminate the reliability issues due to sump and the pump design.
On previous R32's I have built I always went for trust deep sump and Tomei oil pump. But hitting the sump on speed bumps drive on ferry's, was an issue that is always on your mind.
Inlet I went for the Nismo plenum to improve fuelling of cylinder 6 and better flow from standard. Apexi GT spec intercooler keeps temps down.
Exhaust systems built for response, the 6Boost manifold can not be appreciated once fitted. As a lot of engineering goes into the collector, where the 6 cylinder join. Where other manufactures just cut and weld the pipe work together. New Garret GTX twin scroll promised good response and being a Garret reliability is good, with healthy hp for a track, Fast road car.
If you are asking what hp the block is good for, you would have to look at Tomei forged rods
Hope that helps
Discussion Starter · #14 · (Edited)
Reasons for engine components, this is tomei's incite to the 2.8
http://www.tomei-p.co.jp/inf/pdf/41_ae_Letter.pdf
I collected the parts individually
New N1 Block just a better stronger block, R34 blocks go porous, due to thin cast and running high pressure radiator caps.
Greddy pistons for the extra cooling of the crown
Tomei rods proven reliability
Fardons crank made in UK, make cranks for many big name company's and race proven.
Nismo bearings for longevity of the crank (softer than acl meaning when it does come to a rebuild you change bearings not the crank)
Tomei 1.2 muliti layer steel head gasket giving 2770cc and 8.6 compression
RB motorsport to put it all together.
I'm sure everyone spec's to what they know are reliable components and that is what I've done.
This is in Tyne and Wear!? And I haven't seen it before!? :( Will it be coming out at all before the sale? Would love to this I've only ever seen one R34 before (IMS's)
Discussion Starter · #18 ·
Afraid not Ill be polishing it when I get back. Ive not driven the car for 8 months, If I go driving it, it will only make it harder for me to sell.
haha so true mate, it was the exactly the same with mine, wanted to sell it but kept having second thoughts every single time I saw it.
amazing car, worth the money, market is slow but the right buyer who appreciates what it is will always come along sooner or later.
best of luck with the sale mate,
1 - 20 of 61 Posts
