GTR Register Trader
Front and Rear Slotted Disc Upgrades
To fit 2011 onwards models of the Nissan GTR we have produces 405mm front discs and a matching slotted rear replacement disc.
(These will not fit earlier models due to the calipers having a narrower radius throat)
These are the largest disc that will fit the standard calipers and they are manufactured to the same outstanding quality as all our race discs within very tight tolerances.
Disc Specifications
1) Patented slot pattern for more bite, improved release,
more efficient pad cleaning, and improved thermal stability.
2) High Carbon Alloy with copper and molybdenum for
high temperature strength and crack resistance.
3) Aircraft quality heat treatment for micro structure
alignment and durability.
4) Runout less than .0005 inches and thickness variation
less than .0002 inches reduces Judder and Pulsation.
5) Vanes turned OD and ID for balance to reduce thermal
distortion and vibration.
6) 47 or more vanes for superior thermal capacity.
7) Surface finish less than .7 microns for reduced drag
and more consistent coefficient of friction.
8) 100% measured and inspected to meet strict
tolerance specifications.
These 2-Peice discs use our patented V2 mounting which is a light weight solution with excellent durability that allows for float.
For any further information please contact me via email ([email protected]), call (+44 (0) 1295 221 023) or PM me.
Best regards,
Charlie
