THIS KIT IS MAINLY DESIGNED FOR ANYONE WHO ALREADY HAVE MY DOOR BASS SPEAKER UPGRADE AND WANT TO FINISH UPGRADING THE FULL DOORS TO NEW SPEAKERS BUT CAN BE INSTALLED WITHOUT THE BASS SPEAKER OPTION
Suitable for 2009 to 2021> R35 GTR's
After many hours of development work on my own GTR, trying different combinations of speaker sets, with the goal of getting a great sounding upgrade for the front doors without having to get involved in installing a new amp and the wiring that going along with it, this mid range and tweeter upgrade kit uses top quality Hertz components in a kit form with supplied fitting spacers, custom plug and play wiring looms and fitting accessories which makes this an easy, do-it-yourself upgrade
The kit includes a midrange pair from the Hertz Mille Pro line with its Symmetrical dual Neodymium magnet structure and double layer voice coil wound on a Polyamide former with 8 decompression holes, for exceptional power handling and compression-free reproduction. This driver makes for some awesome vocals.
Of course, not to forget the 1" Hertz Mille Pro tweeters with its tetolon fibre soft dome, for a natural yet detailed reproduction of musical nuances and centre Tuning Duct geometry, for lower resonance frequency and reduced harmonic distortion. With a high density flux Neodymium magnet, it complements the midrange to add a sweet sounding high end.
The last main component in the kit, and one which is super important, is the passive crossovers. Only required to split the midrange and tweeter signal coming in from the stock amp, this massively upgrades the OEM setup where the tweeter has a little capacitor stuck on the back, to crudely remove the midrange sound and the mid range is asked to produce all frequencies, including tweeter, until it can produce it no more through natural characteristics of a larger cone. I've included a Hertz Mille Pro MPCX 2TM specialist passive crossover which is designed specifically to split the audio frequencies in the mid/tweeter range. It has a higher crossover point than most passive crossovers and allows more vocals to be produced by the midrange and only the real crisp high end to be produced by the tweeter.
The kit comprises :-
1 x Pair of Hertz Mille Pro MP 70.3 Midrange Speakers
1 x Pair of Hertz Mille Pro MP 25 1" Tweeters
1 x Pair of Hertz Mille Pro MPCX 2TM Passive Crossovers
1 x Pair of 3" Midrange custom made spacers for easy fitting of mids in the stock locations
Wiring to the crossovers pre-made with PnP cables to connect directly to the OEM wiring
1 x Sound Deadening sheet to aid the fitting of the crossover without drilling into the doors.
1 x Fitting Instructions with colour pictures (~20mins per door)
Everything fits behind stock grills and looks OEM when you have installed.
Price is £329 and can be purchased on my website here :- Ultimate MID / TWEETER Upgrade – Plug and Play
266087
266088
266089
266091
