1 - 16 of 16 Posts
Drove my car into work on Friday (10 miles), was fine in the morning but when I set off home it would not accelerate in any gear, just really flat and would not let me go any faster than 55mph. No display lights on the dash, nothing. Tried it again later, still the same.
Getting it checked out this Friday, just wondering if anyone else has had this issue.
2018 with low mileage and Stage 1 map.
Don't have an Ecu Tek dongle to check fault codes.
Thank you all very much. Working away from home at the moment so won't be able to try it out until the weekend. I'll update you on outcome.
Discussion Starter · #14 ·
Just an update.
Turns out it is the Valet Mode function on the Stage 1 Map that was causing the problem. Didn't know it had it.
Thanks to Davec4 and confirmed by Autotorque.
Best not explain it on here but if you have the same issue contact your tuner.
1 - 16 of 16 Posts
