Hi all,
I did my search before posting.
I am trying to find the piston diameter of rear OEM brake caliper's piston size.
Does anyone know this information? I have the piston diameter of the front, but rear is still unknown. Nowhere to be found here and google.
If you know please help out. Thank you.
Regards,
Sam
Discussion Starter · #2 ·
GT-R OE rear caliper piston size
Well, seems like no one has this information.
When I changed into ATS' Big Brake System, I took NISSAN OE calipers out and measured them and post the info here just in case anyone needs it.
Front caliper
6 pistons total
3 piston per side
#1 32.5mm
#2 30.5mm
#3 26.5mm
Total piston surface area is 42.24 cm^2
rear calipers are 4 pistons same size overall.
piston diameter is 26.5mm
Total piston surface area per caliper is 22.06cm^2
Sam
