Hi thanks for response much appreciated, not had any issues so far with clicking, put copperslip on hub but never greased wheel nuts. Can you expand on what should be greased.147nm mate....stops the clicking sound appearing if everything is properly greased up.
Do you know what the torque settings are for H&R spacers?WARNING if you have spacers fitted the torque is to high. I stretched my rear studs. This maybe down to being aftermarket 15mm longer and having a 10mm spacer fitted.
Big thanks to JM Imports for getting me out of the poo again. Great crew they have and will go that extra mile just to help you out.
