just changed the coolant in the car
car is fitted with an arc radiator with arc air removal tank.
i have a hose coming from the bleed screw to an alloy tank that then goes
to the expansion tank.
so does it self bleed ?
thanks.
Yes. Just fill up coolant in radiator and reserve tank to the max level. In the breather tank, keep it a bit less than the top. You should be good to go. Check your coolant levels after a good drive once its cooled down.
One of the best things I ever added to my car.
