Hi all out there... Just one for you,the black plastic cover that's bolt's on to the rad has a big crack in the bottom of it.. :mad: so I'm thinking of just taking it of.... What do you think... Any one... Is there any pros and con of having it on or can I just get away with out having one one.... Any come back helpful.
I ran without one on my last 33 with ally rad with no probs although I was running a degree or two hotter because with the fan shroud it concentrates the air into the rad instead of cooling half the engine bay first if you know what I mean
Discussion Starter #4
Cool... Thanks for the info :thumbsup:I'll probably just take it off then if it not going to effect the efficiency too bad
