Administrator
G310GS Tractive Rear Shock(Low)-RRP 837
Product Code: RRP 837
Availability: 4-6 weeks
Price: £478.80
Ex VAT: £399.00
Available Options
* Spring Rate:
--- Please Select --- 110nm 120nm 130nm 140Nm
Qty:
- OR -
Add to Wish List
Add to Compare
G310GS Tractive Rear Shock(Low)-RRP 837G310GS Tractive Rear Shock(Low)-RRP 837
DescriptionRelated Products (2)
Low seat height/travel RRP/Tractive rear suspension upgrade. Suitable for BMW G310GS only 2017-on.
This is for the REAR SHOCK ONLY, if you require the fork upgrade kit, this can be ordered separately as RRP 840.
The aluminium-bodied Tractive Shock gives a weight saving of over 1,5Kg compared to OEM unit.
Also fitted, as a standard feature, is Tractive Suspensions own unique length adjuster,incorporated into the lower shock mounting.This allows the shock length to be reduced by up to 8mm, by undoing the locknut and winding in the lower mount.This 8mm adjustment at the shock equates to a reduction of between minus 10mm and minus 35mm on the seat height, compared to the OEM shock,allowing the rider to personalise the ride height to suit conditions.No need for any internal shock modifications,or after-market linkage parts to reduce ride height.
Rear shock: High-quality aluminium body with adjustable preload. Choice of four spring rates, softer/standard/harder/extra hard. Easily accessible combined damping adjuster (affecting 80% Rebound and 20% Compression), positioned on lower fork of shock.
Choice of four spring rates, 110Nm, 120Nm (standard) 130Nm & 140Nm.
Spring rate guidelines:
Rider weight (inc clothing and light luggage (15Kg) Total up to 85Kgs = Softer Spring 110Nm
Rider weight (inc clothing and light luggage (15Kg) Total 85-105Kgs = Standard Spring 120Nm
Rider weight (inc clothing and light luggage (15Kg) Total 105-120Kgs = Harder Spring 130Nm
Above 120kgs total rider & luggage weight select 140Nm spring, this is the maximum weight spring offered.
NOTE: IT IS NOT POSSIBLE TO FIT THE REMOTE HYDRAULIC PRELOAD ADJUSTER RRP 844
2 year TracTive warranty
Rally-Raid Products Ltd are the UK distributor for Tractive Suspension, and also their nominated Service Agent in the UK, with all necessary tools and equipment to offer buyers a complete technical service and repair facility. This includes stocking all genuine Tractive Suspension shock absorber spare parts, along with their own design of vacuum pump, to enable the shock to be bled 100% when re-filling with oil.
LEVEL 1 and Low Shock Fitting Instructions
Tractive Pt. No. 46BM18-R1294
TRACTIVE SUSPENSION MANUAL LINK
