41 - 60 of 71 Posts
looks good.... one recommendation
loose the 90 deg coupler on the turbo..... weld in some pie cuts and use a straight coupler or wiggens/vanjen clamp ;)
Discussion Starter #44
4" Downpipe is wrapped...
Mocking up the front wastegate dump tube... our welder was off so I had to try my skillz :p
Ace doing some last modifications to the harness before wrapping it...
Haltech Dual Channel Wideband wired into the harness...
Ace finishing up the wiring...
RacePak installed...
RacePak is active...
Discussion Starter #48
Ricky, keep the "swag" to a reasonable level, you don't want to hurt yourself!:flame:
Build looks great dude, did you end up hooking up the crank trigger from ROSS?
Not on this build. Going on another.
Discussion Starter #49
Added some finishing pieces to the engine bay...
R34 GTR Coil Cover badge
Custom catch can
Carbon fiber cooling panel
First pass in Cleaning up the fuse box
Discussion Starter #51
So had made some exterior changes this month... Including is the DMAX Hood, Origin Lab Corner Lights and winkers.
Also got some new gear from Nissan including a JDM S14 Front Bumper, JDM S14 grill, JDM Headlights...
the result thus far... what do you guys think?
Discussion Starter #59
After about 8 months of having fun driving her... she is now torn back down and in for some paint...
41 - 60 of 71 Posts
