Raybrig R1000 Twin Lighting System Compact Spot/Fog lamp from Japan. Both Spot/Fog lamps can be turn on at the same time, Spot lamp for far distance vision & Fog lamp for broad vision. Raybrig Hyper-Halogen (H3) bulbs are used for both Spot & Fog lamp bulbs.
Product Spec.:
Part#FK02 (SPOT: Platinum White/FOG: Platinum White)
Height = 50mm, Width = 145mm
For 12-volt use only, Consumes 55-watts X 2 of power
includes mounting brackets, switch, full loom... everthing needed!
£50
Product Spec.:
£50
