www.prpeu.com
from €320,00
If you need to inquire about this part please email us at [email protected] or click on the icon.
This new generation coil kit has been completely redeveloped and specifically designed as a direct drop-in replacement for the OEM RB20, RB25, RB26 Heads that are becoming more popular.
These coil kits incorporate Genuine Hitachi R35 GTR Ignition coils and put out near 3 times the OEM power output, the R35 coil kit can be used as a direct plug-in for OEM Ecu's as well as any other aftermarket ECU available, to maximise performance use the dwell data that can be found on our web page.
Key Features:
  • Billet Alloy anodized bracket is engineered to fit all ignition coils in a way that allows user-friendly access to all the coil plugs and spark plugs in a non-invasive manner.
  • Kit now includes custom height quality one-piece silicone injected spark plug stalks that seal the spark plug well, avoiding water pooling and inherent engine misfires.
  • Custom made springs already fitted inside the stalks make for extremely fast installation as well as no trimming of springs required.
  • Coil kit fits well under the valley cover without ANY modification.
  • Bench tested, club motorsport grade branded harness, high temp Tefzel wire and crimp joins used with OEM connectors and glue lined heat-shrink
  • Now clears HKS VCAM * Genuine OEM Hitachi coils are rated to 2600 hp and come with a 1-year warranty.
  • Bolt kit included caters for the 6 ignition coils and billet bracket to head.
  • Standard colours are now Black, Purple, Red, Silver, Blue with custom order colours Gold, Teal, Green, Teal, Orange, Grey. * Lifetime warranty on all PRP products.
RBLOOM1 R32 GTR - 6pin igniter delete big 3pin grey power
RBLOOM2 RB25 - 7pin igniter delete small 2pin grey power
RBLOOM3 R33 GTR -
6pin igniter delete small 2pin black power
RBLOOM4 R34 GTR -
8pin harness connector
RBLOOM6 RB UNIVERSAL -
dt8 deutsch connector end
261941
261942
261943
261944
261945
261946
