I am going to buy a rb20 lump of someone soon, and he told me that there was a slight little end failure, he has gone for a rb25 swap, so is selling the engine.
I no the little end failure is the small bolts under the crank rods right? Is there somewhere i can replacements from, or do i have to go to nissan? Also what else may have gone down the drain if his had this problem?
What gearbox can i use with the rb20 because he isnt supplying me a gearbox.
I want to rebuild the engine as much as i can then use it once its all done, any advice would be great!
