1 - 14 of 14 Posts
As some of you may know i have been doing a RB25 s13 conversion for sometime and now it's time to draw a line under it and move on to something different so all my RB parts are up for grabs appart from the engine open to sensible offers for all parts..
Turbo set up
T3/T4 Honeywell Garrett TA3410 turbo,xs power external wastegate(1.4 bar spring), braided oil feed and return with fittings, custom downpipe and front pipe with screamer recirc,top mount mani wrapped £900 ono
Turbo spec..
360 Degree Thrust Bearing
Oil lubricated centersection.
Manufacturer-GARRETT
Model- TA3410
Serial Number -715583 5007
T3 Flange
4'' Inlet
Compressor (A/R) .70
Turbine (A/R) .82
4 Bolt Exhaust flange
External Wastegated
Good for 500- 600hp
Inlet plenum damaged £150ono
Custom rb prop rb front half and bearing ca rear half £100ono
R33 gtst gearbox low milege £300ono
ACT RB25 Clutch and Standard RB25 flywheel £300ono
Apex Performance Parts Ltd | Nissan 200SX parts specialists | Innovate Motorsport Dealers
Power fc + controller mapped for 550cc on 1.4 bar Provisionally Sold
Clear rb25 front cover £50ono
fuel pressure reg £70ono
R33 crossmember cleaned and sprayed in hammarite smooth black plus custom rb25 gearbox into s13 mount £90ono
Splitfire coilpacks £250ono
Will add photo's later and tomorrow if there are certain photos you want please let me know all items can be posted at buyers cost..
Turbo setup..
Size difference to a t25
Modified downpipe (fully wrapped)
External W/G (fully wrapped
Top mount (fully wrapped)
Gearbox..
Gearbox mount
Discussion Starter · #12 · (Edited)
Price drop and updated list
Turbo set up
T3/T4 Honeywell Garrett TA3410 turbo,xs power external wastegate(1.4 bar spring), braided oil feed and return with fittings, custom downpipe and front pipe with screamer recirc,top mount mani wrapped £850 ono
Turbo spec..
Model- TA3410
T3 Flange
4'' Inlet
Turbine (A/R) .82
External Wastegated
Good for 500- 600hp
Polished RB25 rocker covers £130ono
R33 gtst gearbox low milege £280ono
ACT RB25 Clutch and Standard RB25 flywheel £280ono
Power fc + controller mapped for 550cc on 1.4 bar £450ono
R33 crossmember cleaned and sprayed in hammarite smooth black plus custom rb25 gearbox into s13 mount £80ono
1 - 14 of 14 Posts
