1 - 7 of 7 Posts
Wanted
Complete RB26 DETT engine with turbo’s, manifolds, etc
Also RB25 sump
Also RB26 ecu & loom.
For engine swap into S14.:clap: :clap: :clap: :clap: :clap:
i have some standard turbos and ecu for sale NISMOMAN
i might know of someone who has a full rb26 with about 12k miles on it. it's mint and won't come cheap but it's as good as they come apparently.
Is that James's motor? :)
R33 RB26 DETT - Complete
Hi,
I have a complete engine that I was going to advertise later on this year.
Its not one of those dodgy ones where you pay top dollar and take all the risk only to find out that its knackered once you get it in.
The engine is complete with loom, ecu, turbos, air intake, AFMs etc etc etc. They are all bolted off the engine. The head is off the block and the oil pan off the bottom end.
The reason for this is that you can inspect the head and the cylinders and even take off a bearing cap to check the bearings and the crankshaft.
I now know not to chuck two and a half grand at an engine without doing the above!
The head is ported and fully shopped with all new valve guides. It has been pressure tested to make sure that it is not cracked!
If you are interested then give me a call 07957 887994
Andy
1 - 7 of 7 Posts
