Now the stagea has its new forged RB28 engine installed the following are up for sale
N1 bottom end .
Genuine 24u block , standard crank and N1 pistons , with cases pump oil pump etc
Dismantled checked and all good . £1900
May split if not sold in a week or so
r34 head with valves etc all good £ 750
Set of genuine tomei rods all perfect £575
2 sets on tomei pon cams . Will bolt straight in without extra work so an easy install
1 set for r34 with 34 CAS so will fit on 32/33 £ 495 ( inc CAS )
1 set for R32/33 - £375 or £495 with tomei adjustable pulleys (also have 33 CAS if required)
Trust oil pump produced very good pressure bought new only 3000m old £575
Also have a complete 33 head with water gallery mod complete with valves etc . This will be available in about 10 days
set of standard rb26 covers in excellent condition . rocker cover, cam cover and plug cover £ 180
I also have another full set of rb26 high gloss red covers , These used to be on the stagea and come with tomei engine plate . Possibly sold
accusump with gauge , pipes etc but not electronic switch £275 Still workd perfectly.
also have a set of splitfire coilpacks £240 working perfectly only for sale as I just upgraded
big bore downpipes £140
More parts to follow and I will take some pics and post them up over the weekend
And just so there is no confusion,
If anybody is coming to see parts ( which of course is fine) then I will hold them
N1 bottom end .
NO DIBS !!!! . PARTS WILL BE SOLD AN A FIRST COME FIRST SERVED BASIS. If anybody is coming to see parts ( which of course is fine) then I will hold them
