1 - 6 of 6 Posts
Hi All,
I have a question for you, Not being too technically minded.. Can anyone tell me what is the difference between an R32 and R33 Vspec engine, Is the block the same?
Thanks..
Hornet
Skyline Section Manager
The v-spec engine is no different from the non v-spec engine. The R33 engine has a wide oil pump drive on the crank. Thats the only mechanical difference.
RB26
Thanks for your help..Question, are they interchangable could I use the 32 to replace the 33 block? in view of the oil issue..
All RB26 parts are interchangable(exept the CAS). A R33 crank in the R32 block is common.
1 - 6 of 6 Posts
