For sale. My fully forged RB26 engine with full counter billet crank. Fresh engine, not run since complete proffesional re-build.
This is my spare engine from last season. It made 750 BHP @ the wheels @ 1.9bar using a GT42. I still have the dyno graph to prove this.
The engine had a no expense spared re-build ready for 2010. My new car that is on its way from Japan already has a fresh engine and I have my 3.0l engine with dry sump ready to go in if needed meaning this one is no longer required.
Here is a list of the full spec
Full step 2 cylinder head gas flowed & ported
8 new inlet guides
Full set of HKS valve seals
Step 2 cam shafts
Step 2 springs
Step 2 buckets
HKS cam pulleys
New kevlar timing belt
New cam seals
1.2mm steel head gasket
Rear head drain
Full counter billet crank
Carrillo con rods
Custom made 86mm wossner pistons
ACL mains and big end bearings
Custom auto select sump extension and pick up pipe
N1 water pump
Reinik group N racing oil pump
Engine on a pallet ready to go.
This is a mega high speced engine.
£6500.
Contact Mark on - 07725 509954
8 new inlet guides
Step 2 cam shafts
Step 2 springs
Step 2 buckets
HKS cam pulleys
New cam seals
Rear head drain
Carrillo con rods
N1 water pump
£6500.
