hi thare
i have head(272 cams-spring-borbing) 32-33 and i wana put it in my r34 eng but i dont want to change cam sensor and cut wairs >>>
then what will i do? can i put anew only 34 272 cams on 32-33 head becuase i wana use my 34 cam sensor without cut and change >>>
all r32/33/34 head castings are the same
r34 cam/sensor is different to r32/33
easiest fix would be to order the correct exh cam to suit the sensor or fit earlier sensor & rewire
