Hi everybody
I am in the process of fitting a Nismo Long Runner Intake Plenum to my R34 GT-R (writeup coming soon), and here´s what I found (see pic, black marks on the intake flange upper left).
I have read about this in another, older thread, before, but of course I didn´t think I might be affected.
Fact is, the gaskets between the intake and manifold and the throttle bodies and the ones between the throttle bodies and the plenum (all the same, BTW) get brittle and start failing. Depending on the extent of leakage, symptoms may vary from not having any effect at all to having the affected cylinder(s) run rich.
Nismo has some high quality gaskets (find them on RHDJapan´s website) with a special coating which may seal better and last longer, but interestingly they do not include them in the kit (standard gaskets are supplied, though)...
Only chance to check is to perform a boost leak test which requires some dismantling and fabricating a fitting to pressurize the intake system from the turbos on.
Changing the gaskets, however, is serious PITA, let go changing the plenum...
Peter
Peter
